V-Ray 5 renders an image that is hidden
V-Ray 5 renders an image that is hidden (including through tags), in V-Ray 4 everything happened correctly.
It only helps to explode the image (then it gets as material in the asset editor), but it is more convenient to correct this omission.
Hi @aleksey_dremin
Thank you for the feedback! The issue has been logged (SK - 3201)
In the meantime, as a workaround if you explode the entity and re-group it again, it should rendered accordingly.
A fix for this issue will make it in the next update.
