There is a very annoying thing about new frame buffer window appearing behind Maya window on MAC OS. Resetting / showing frame buffer from the setting window does nothing.
This does not happen on Windows system.
Any chances to resolve this and keep VFB 2.0 on the top all the time ?
Thanks,
Karol
Hello Karol.Osinski,
We do know about the existence if this issue and our developers are still investigating the root cause of the problem.
This is the internal bug-tracker ID: VMAYA-9612
On the other hand, can you please check if this is happening when the VFB2 window is maximised?
Kind Regards,
Dimitrina
Hi @Dimitrina.Milanova , thank you.
When VFB2 window is maximised I can’t really select anything inside Maya to make the frame buffer disappear.
