I can not drag and drop some materials from the library to the Scene Materials.
Hi @javierrentas !
Another way to import a material is using the option Add To Scene from the context menu which is opened with the right mouse click on the wished material. Does it work this way?
Is the selected material (that you want to add) in the loaded directory for sure?
Would you share the vrayneui log file (V-Ray > Help > About > V-Ray Asset Editor Session Log) after you reproduce the issue, please?
Thank you for your report.
Regards,
Ivelina
If I right-click and select “Add to Scene” the material is transferred to the Scene material.
How can I share the .log file?
Hello @javierrentas ,
Thank you for the additional information.
You can attach the vrayneui log file in this forum topic, you can send it to me in private message or you can send it through our support portal (https://support.chaos.com/hc/en-us/requests/new) by mentioning mandatory in the message the link from this forum topic.
Regards,
Ivelina
Dear @javierrentas !
Thank you for sending me the .log file! We identified the problem and our dev team will work on fixing it this week.
Regards,
Ivelina
Thank you Ivelina for your help!
