V-Ray 6 & 7 on same machine / maxversion
Is it in any way or form possible to have both V-Ray 6 and V-Ray 7 installed side by side in the same Max version as different render engines ?
Having to upgrade all our V-Ray 6 installs to V-Ray 7 will basically murder 40 of our rendernodes since they don’t have AVX2. So I am looking for a way to be able to continue
usingV-Ray 6 mainly, but ALSO be able to start using V-Ray 7. Any help and or insight would be appreciated.
Not directly in 3ds Max, but you can have two V-Ray versions installed for the same 3ds Max by installing V-Ray in an arbitrary location and having two separate shortcuts (.bat files), loading the relevant environment variables for each version. Check this docs page.
