v-ray enmesh modifier not working with any shape with extrude even i convert it to editable poly
any solutions for it
Might want to show the problem with a model or some screenshots.
when you apply v-ray enmesh modifier on shape with extrude or shape with edit poly modifier Not Appear in the render
Do you get any messages in the error log ? In a simple experiment here I get a message that the extruded mesh has no mapping channels - Enmesh requires UVs to function. If I add an UVW Map modifier to the extruded shape - Enmesh renders ok.
Yavor
Thanks a lot its working when I add uvwmap modifier.
Welcome ![]()
