V-Ray 6 for Cinema 4D Update 2.5 is now available
Hey everybody,
V-Ray 6 for Cinema 4D, Update 2.5 is out.
​​​​​​The builds can be downloaded from the Downloads section on our site.
Here is the change log for release version 6.20.05
Modified features:
  • Add support for instance rotations for the new Particle Emitters
  • Add support for User Data Tag
  • Handle scene-linear Rec.709-sRGB and ACEScg bitmap import
  • Add -skipHome command when initiating LiveLink to prevent the Vantage Home screen from appearing​
Bug fixes:
  • Incorrect result with animated Bend Deformers in V-Ray Standalone
  • Missing “Vertical FOV” setting in the Overrides settings when the Camera is set to Spherical Panorama
  • Freeze when Render Node License error is encountered
  • Light Cache build fails at start of build, crashing of V-Ray GPU
  • Fix crash with new default camera
  • Crash when an empty Instance object is used
  • Particles will render earlier than expected in V-Ray Standalone
  • Node material previews in some scenes will be refreshed after loading
  • Cinema 4D crashes when reloading cosmos assets
  • Chaos Scatter is always re-exported during interactive rendering
  • V-Ray Material does not support animation for Cinema 4D Noise Shader
  • V-Ray crashes when a source with object properties tag is cleared from Enmesh
  • Animated material change is not functioning in V-Ray Standalone
  • Color management problems in Cinema 4D 2025
  • Material Override does not work without a material
  • Materials are not linked to selections when importing a V-Ray scene containing Multi/Sub-Object
  • Interactive does not update any V-Ray Volume Grid​
