V-Ray 6 for SketchUp, update 2.5 is now available!
It can be downloaded here:
download.chaos.com
After installation, you will find more detailed info about the changes in the ‘VRayForSketchUpReleaseNotes’ file:
Windows: %PROGRAMFILES%\Chaos Group\V-Ray\V-Ray for SketchUp\extension\
macOS: /Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/
Regards,
Konstantin​​​​
Improvements & bugfixes
  • An issue affecting the correct functionality of VRScan materials is resolved. The default configuration for each VRScan now loads correctly and is fully editable
  • The new Glass material mode introduced in Enscape 4.1 is now compatible with V-Ray
  • The handling of Enscape material textures stored as bitmap buffers within SketchUp is improved
  • The license requirement for connecting to Vantage via Live Link is removed
  • GPU: An issue related to rendering of backfaces is resolved
  • GPU: An issue causing a memory leak during animation sequence rendering is resolved
