V-ray 6 Hotfix 2 - 3dsMax crashing
I just updated to V-ray 6 Hotfix 2 for 3ds max (2021) and as soon as I open the material editor and try to do anything, Max crashes and closes with the typical message:
Can you please help what might be causing this issue?
should I just go back to vray 5? that at least worked..
Could you attach the “3dsmax_minidump.dmp” file (it is located in the windows temp folder)? Make sure it is a recent one by crashing it beforehand.
hello there
cannot attach it as it exceeds file size limits, I’ve uploaded it here: https://files.fm/f/u2ndwzq64
I hope this works.
Thanks for the provided crash dump.
You should clear crack files from previous versions and it should work.
Yavor
hi,
can you please elaborate on this? I’m not sure what to clear from where exactly.
You have these two files:
C:\Program Files\Chaos Group\V-Ray\3ds Max 2021\bin\plugins\vray_v41003_max_fix.dll
C:\Program Files\Autodesk\3ds Max 2021\Plugins\vrayplugins\vray_v41003_fix.dlr​
Those are not part of the official V-Ray installation and are known parts of the pirated illegal V-Ray.
