We are currently running renders using Deadline, but we have encountered an issue where rendering hangs under specific conditions across 20 nodes with the same specifications.
We would like to check if there have been similar reports or if there is any known workaround/solution for this issue.
[Issue Description]
On 20 identical machines, when rendering with V-Ray 7.40.04 using GPU rendering, the process halts after outputting the following log:
V-Ray: Exporting scene to V-Ray.
This occurs regardless of the scene file (it hangs at the exact same point across all scenes).
On other machines with different hardware configurations, GPU rendering with V-Ray 7.40.04 works without any issues.
[Troubleshooting & Findings]
V-Ray Version Downgrade: When downgraded to V-Ray 7.40.02, GPU rendering completes successfully on these 20 machines.
Engine Switching: On V-Ray 7.40.04, switching to CPU rendering allows scenes to complete successfully (the freeze only occurs when switched to GPU).
NVIDIA Driver Versions: We tested the following driver versions, but none resolved the issue:
[Environment of Affected Machines (20 nodes)]
OS: Microsoft Windows 11 Pro (10.0.26200)
CPU: AMD Ryzen 9 9950X3D2 16-Core Processor
GPU: NVIDIA GeForce RTX 5080
V-Ray Version: 7.40.04
The OCIO support utilizing cg-config in this version is critical for our workflow, so we strongly prefer to avoid downgrading if possible. We hope this can be addressed in a future update.
Any advice, information on similar reports, or potential fixes would be greatly appreciated.
Thank you.
Sorry, I forgot to include the missing environment details.
We are rendering from Maya 2026. The following details were captured directly from the rendering log:
V-Ray: V-Ray 7 for Maya, update 4 DR2 version 7.40.04 from Jul 27 2026, 20:53:36
V-Ray: V-Ray core version is 7.40.03
Hope this helps clarify the setup.
Please try rendering without Deadline on one of the affected machines
and check if the render exports and finishes successfully?
Is the issue present on all render nodes or only on some of them?
Can you reproduce it when rendering the scene locally on your workstation?
You can also send us one of the affected scenes, and we can try to reproduce the issue on our side.
Thank you!
Thank you for your response.
We have carried out further testing and found additional details regarding the issue:
Local Rendering:
When logging into one of the affected machines and rendering directly from the command line, the render completes successfully.
Root Cause Context:
The issue appears to be specific to running the Deadline Worker as a Windows Service. It seems V-Ray 7.40.04 GPU rendering hangs at V-Ray: Exporting scene to V-Ray. when executed under the Service environment on this specific hardware.
Affected Nodes:
As previously mentioned, this issue occurs on all 20 nodes with identical hardware specifications (RTX 5080 + Ryzen 9 9950X3D2) when running Deadline Worker as a service. Meanwhile, on more than 200 other render nodes with different hardware configurations, GPU rendering works without any problems.
Scene File:
As previously mentioned, this issue is not specific to a particular scene—it occurs with any scene, including a simple test scene with a single default cube.
Given these findings, it seems there is a conflict/compatibility issue between V-Ray 7.40.04 GPU initialization and running under the Deadline Worker Windows Service environment on this specific hardware (RTX 5080 setup).
Could you please investigate if there are any known issues or settings related to running V-Ray 7.40.04 GPU rendering under a Windows Service on RTX 5080 systems?
Thank you for your support.
Thank you for the details. We tested a simple scene with
V-Ray GPU using the latest V-Ray version, 7.40.04.
It renders correctly here with Backburner, which uses 3dsmaxcmd.exe.
Could you try Backburner or 3dsmaxcmd.exe on your side and let us know if you still have the same issue?
Thank you for testing and getting back to us.
Please note that we are using Maya 2026 (using Maya’s batch render command Render.exe), not 3ds Max. Furthermore, because our machines are operating strictly as production render nodes, we cannot easily set up a Backburner environment for testing.
To clarify our environment: As tested previously, logging into the node and running the render directly from the command line works fine. Therefore, we assume it would likely work fine under Backburner as well.
The issue specifically occurs when running the Deadline Worker as a Windows Service executing in the background without any user actively signed in (Session 0).
Under a Windows Service environment where no user session is active, GPU processes operate in a non-interactive Session 0. It appears that V-Ray 7.40.04 GPU initialization hangs under this headless service execution context on RTX 5080 systems.
Could you please test the render process specifically by executing Maya (or Maya batch execution) via a Windows Service running without an active user login? Alternatively, testing the service execution under a different user account would also be very helpful to see if the issue persists.
Thank you for your continued support.
I tested running a V-Ray GPU render job while the user was signed out, using Maya’s render.exe and a .bat file scheduled through Windows Task Scheduler.
I had to configure V-Ray to use a license server on another PC on the network, as the license server on my local PC was not running.
After making this change, the render completed successfully using V-Ray GPU, Maya batch, and V-Ray 7.40.04.
Here are our tests:
https://drive.google.com/file/d/1iB-1qFqAITDWCWGrBF_eyEvAI008hRsD/view?usp=drivesdk
https://drive.google.com/file/d/1F1Pt2Bb2-sZYjf8I_0v10Ulv6ePh9kqV/view?usp=drivesdk
Please check your V-Ray license settings and point
them to a license server on another PC to see if this resolves the issue?
https://drive.google.com/file/d/16Ct0wqLdyVwj0Yaqr96Tk7OZ2G-xwsua/view?usp=drivesdk
Let us know how it goes.
Thank you for your investigation and support. We really appreciate your assistance with this specific and unusual issue.
Regarding the license suggestion, we do not believe this is a licensing issue for the following reasons:
Successful Command Line Renders:
As mentioned previously, when we log into the machine and run the render via the command line, it renders without any issues. If it were a licensing problem, the command line render would fail as well.
(Note: We use VRAY_AUTH_CLIENT_FILE_PATH for licensing, which works seamlessly across all our machines.)
Working Setup on Other Machines:
On other render nodes with different GPU configurations (also running as a Windows Service with the exact same licensing setup and VRAY_AUTH_CLIENT_FILE_PATH), the renders complete without any issues.
This issue occurs exclusively on our RTX 5080 machines when executing as a Windows Service.
Could you please confirm if your test results with V-Ray 7.40.04 were obtained on an RTX 5080 GPU setup?
Thank you very much for your support and for investigating this issue with us.
We are happy to report that we have identified the root cause. The issue was caused by the integrated GPU (iGPU) on the AMD Ryzen 9 9950X3D2 processor.
When executing via a Windows Service without an active user login, the process appears to have conflicted or attempted to initialize the integrated GPU during V-Ray GPU setup, causing the render to hang.
Disabling the integrated GPU (iGPU) resolved the issue, and renders are now completing successfully on all 20 machines.
Thank you again for your time and assistance with this case.
