V-Ray 7 for Cinema 4D Update 4.1
Hello everyone,
V-Ray 7 for Cinema 4D Update 4.1 is out. In this release we introduce V-Ray Paralax texture and support for Cinema 4D 2027
The builds can be downloaded from the Downloads section on our site.
Here is the change log for release version 7.40.01
New Features
  • V-Ray: Support for Cinema 4D 2027
  • V-Ray: Introduce V-Ray Parallax texture
Improvements
  • Chaos Cloud: Introduced a custom export directory option for Cloud submit
  • V-Ray: Enabled support for the “Use Project Frame Rate” option introduced in Cinema 4D 2025.2
  • V-Ray: Implemented support for the shadow opacity optimization
  • V-Ray GPU, VRayTextures: Extended the V-Ray Layered texture with a Divide blend mode
  • Security: Improved security in V-Ray
Fixes
  • Chaos Cloud: Cloud submit fails when the username contains space characters
  • Interactive: Cinema 4D crashes when undoing changes in Render settings during viewport interactive rendering
  • V-Ray: A specific scene with Cryptomatte and Light Cache crashes in Chaos Cloud
  • V-Ray: Crash when editing scatter in interactive rendering
  • V-Ray: Redshift camera is severely overexposed
  • V-Ray: Scenes using Chaos Scatter with distribution maps might crash on Chaos Cloud
  • V-Ray GPU: Crash when VRayBitmap is plugged into the VRayEnvironmentFog’s Fog Color Tex
  • V-Ray GPU: Implement an additional bump mapping mode that is not affected by screen scale
  • V-Ray VFB: Rotating the Vignette layer beyond 45 degrees causes issues with the offset UI handles
  • VRayVolumeGrid: Incorrect shading of backfacing geometry when a Phoenix Simulator, V-Ray Volume Grid, or Environment Fog is in the scene
  • VRayVolumeGrid: Memory leaks when loading volume grids
