Hello everyone,
V-Ray 7 for Maya, Update 4.2 (7.40.06) is now available.
This is a maintenance release focused on security fixes, along with a handful of improvements and bug fixes – mostly on the V-Ray GPU side and around Gaussian splats. Updating is recommended for everyone on V-Ray 7.
Useful links:
Improvements:
- V-Ray GPU: Initial support for stochastic Gaussian splat rendering
- V-Ray GPU: Added a Divide blend mode to the Layered texture (VRayLayeredTex loaded via plugin/import)
- VRayMultiSubTex: Moved the “Add New Item” button to the top of the textures list
- VRaySwitchMtl: Now supports a much larger number of inputs (20+)
Bug fixes:
- V-Ray: Fixed the drag-and-drop workflow for VRayMultiSubTex
- V-Ray GPU: Fixed a crash when a VRayBitmap is plugged into the Fog Color Tex of VRayEnvironmentFog
- V-Ray GPU: Fixed a displacement issue when Stochastic Tiling is used
- V-Ray GPU: Fixed endless Light Cache calculation with certain Gaussian splats when lighting and light illumination are enabled
- V-Ray GPU: Added a bump mapping mode that isn’t affected by screen scale
- V-Ray GPU: Fixed V-Ray GPU ignoring non-traditional normal maps
- V-Ray GPU: Fixed VRayGaussianGeom relighting not behaving well with raised intensity
- VRayGaussianSplat: Fixed Gaussian splat reload issues
- VFB: Fixed bad blending between the environment color and the image layer in the Background
Security:
- Fixes for identified vulnerabilities
Happy rendering!
Best,
Muhammed
