Hi all ~
V-Ray 7 for Maya, Update 4 is out!
Some useful links:
This release adds a number of new and exciting features. Some highlights:
Speed Improvements
This release adds rendering speed improvements up to 13% on Windows and 6% on Linux! Get more beautiful renders in less amount of time and iterate even faster than before.
Gaussian Splat relighting
Easily adjust the lighting of Gaussian Splats to match your scene better. This works best with assets captured under ambient lighting, making it easier to visually incorporate them into CG projects. Use the advanced controls to fine tune your final renders and get the exact result you’re looking for.
Gaussian splats have also gained their very own render element to allow for better and more accurate compositing workflows.
Parallax Textures
Parallax Textures enhance exterior renders by providing realistic interior depth and lighting without requiring extensive modeling or complex geometry. They are easy to apply, lightweight to render, and can be adjusted per window, making them the ideal tool for adding realism to cityscape backgrounds. Apply them on background buildings for better environments, interiors of cabinets and boxes for faster interior design and many other creative setups. Create and use your own textures or make use of the ones provided in the Chaos Cosmos browser!
Veras for render and viewport AI visualization
Use AI to your advantage to complete your ideas and visualise faster. Chaos Veras utilizes Nano banana to create refined images based on a simple render input grabbed from the VFB or viewport and a user generated prompt. Perfect for style exploring and ideation
You can use it at several points of your workflows to save time:
Ideation - Veras will allow you to block out concepts with simple shapes and have the AI generate more elaborate concepts to be used as a guide or for trying out ideas. This can be done both with simple viewport screenshots or with simple renders.
Set extension - you can provide Veras with a render of an asset and have it generate a background as well as integrate the asset with it’s lighting. You can use both written prompts and images as a reference for the AI to go from.
Refinement - it can also be used with more finalized renders for further enhancement, transferring of different artistic styles or for refining details.
Bifrost
This release adds initial support for native rendering of Bifrost nodes. Create customizable and reusable visual effects with procedural graphs and view the results directly in the 3D scene. For now we’ve added support for IPR updates, final renders and animations for meshes, strands, and instances, as well as assigning materials through the graph. Look out because there’s more to come!
Simple Caustics for Sun Light**
Quick caustics offer believable light patterns for common scenarios like pools and water features. This approach avoids the high cost of full photon tracing, delivering simple realistic water caustics with significantly less setup and good performance.
Out-of-Frustum Displacement control
Reduce your RAM usage for complex scenes and improve performance without sacrificing the quality of you final renders.
VFB Improvements
New Image Layer
Gain complete control over the VFB’s Image layer - get the exact right position, rotation and scale with the help of new handles. Use repetition and blending options to create watermarks or other custom effects and iterate quickly in the VFB without re-rendering or switching software.**
Histogram**
Gain more insight into the values of your render and dynamically display the results of any made adjustments.
More
Added support for MayaUSD 0.36.0 for Maya 2027, 2026, 2025; MayaUSD 0.35.0 for Maya 2026 and 2025, Bifrost 3.1.0.8 and 3.0.0.0 as well as HIP support for AMD GPUs allowing you to be on the latest and greatest and make use of technological advancements.
Quickly populate your scenes with curated groups of Cosmos asset sets
We’ve also added some minor Toon Improvements - Global width multiplier for faster control of toon lines on a global scale; support for Depth an Angular control on shader level; and Inner and Outer outline constrains the toon outlines within the mesh, outside of it or on its edge (middle) allowing for easier masking and customization.
For Full Changelog you can check out bellow or the release notes
Give these a whirl and let us know what you think!
And as always, happy rendering!
