V-Ray 7 for Rhino, update 2.1 is now available!
It can be downloaded here:
download.chaos.com
A complete list of all new features and improvements is available in the Release Notes
Regards,
Konstantin
Improvements
  • All Enscape compatibility menu entries are now grouped together under V-Ray > Enscape Compatibility
  • Added support for the new Enscape Cosmos Assets (Enscape 4.11 and later)
  • A new Download Enscape Assets option is added in the Enscape Compatibility sub-menu. When necessary, it can be used for downloading assets without relying on Enscape
  • The shadows cast by Rhino’s Directional light now better match the native appearance (softness)
  • The V-Ray Scene Importer’s handling of clippers is improved
  • Clipping planes are now rendered even when hidden in the viewport which matches the native Rhino behavior
  • Added support for multi-import of Cosmos Assets via drag and drop into the Asset Editor
  • V-Ray plugin names can now be changed with a Python script
Bug fixes
  • Selecting a new Generic material in the Asset Editor no longer prints a warning in the log
  • An issue causing an Asset Preview crash when swatch scenes are changed quickly is resolved
  • Changing the UI Color Theme from the Asset Editor’s configuration now correctly changes the theme for all V-Ray windows
  • The AI Image Enhancer icon is now correctly greyed out when there is no Enhancer Data render element present
  • A crash caused by an Enhancer Data render element in specific situations is resolved
  • An number of issues with importing vrscene files from SketchUp are resolved (via the V-Ray Scene Importer)
  • An issue causing errors when starting Resumable Rendering after restarting Rhino is resolved
  • A crash on render after releasing the V-Ray license in specific situations is resolved
  • Scattered lights can now be turned off
  • Spline scattering setups now update correctly during interactive rendering
  • Closing Rhino no longer stops Vantage even when Vantage was started as a child process
  • A typo in the Chaos Account window is fixed
  • An issue causing incorrect migration of Clippers is resolved
  • An issue with the file paths of newly created Dome or IES lights is resolved
  • An issue with lights’ color control in Rhino is resolved
  • An issue causing different Enscape assets to incorrectly share a bitmap buffer is resolved
  • An issue preventing specific Enscape assets from rendering in V-Ray is resolved
  • Grasshopper: An issue preventing the Custom Preview component from rendering in Rhino is resolved
