V-Ray 7 Personal Learning Edition (PLE) for Maya - now available!
Helloo~
The PLE version of V-Ray for Maya is updated to V-Ray 7! :slight_smile:
Get V-Ray 7 PLE.
If you’re not an existing V-Ray PLE user, you can register here.
With V-Ray 7 PLE you can learn and explore how to:
  • creates a detailed, three-dimensional representation of real life assets and environments with Gaussian Splat rendering support
  • get consistent shading results between platforms and renderers with OpenPBR support in MaterialX, as a native Maya material or as a mode for the V-Ray material
  • reduce render time and artifacts with Firefly removal
  • create beautiful skies with the improved PRG sky model
  • enjoy various VFB improvements such as custom regions, vignette layer, color correction presets and more
  • populate scenes faster and better with Chaos Cosmos Asset Variants, multiselect import and V-Ray Light Luminaires
  • improve your GPU rendering with Caustics, faster animation rendering and time to first pixel, as well as support for Apple Silicon chips.
    and many many more
Learn more about what’s new in V-Ray 7 PLE.
Happy rendering!​
V-Ray 7 PLE for Maya – Roughness bug preventing educational adoption
Hi Chaos team!
I’m a LookDev and Rendering professor at a animation and VFX college.
We’re currently using Maya 2025 with V-Ray 6, and the only reason we haven’t moved to V-Ray 7 is the roughness issue in the PLE version.
We’ve noticed that switching the VRayMtl shading mode to OpenPBR resolves the issue. However, this isn’t a viable workaround in our educational environment.
Our students follow a progressive learning structure, starting with the traditional VRayMtl workflow and gradually developing more advanced shading skills. Switching to OpenPBR changes the material interface and parameter terminology, such as Refraction becoming Transmission, which would create unnecessary confusion, particularly for students in their final semesters working on graduation projects.
We need to maintain consistency between classroom instruction, existing projects, and the software students use at home. Unfortunately, the roughness issue prevents us from adopting V-Ray 7 while preserving that continuity.
I noticed this issue (VMAYA-13463) was reportedly fixed in a later V-Ray 7 update (7.10.00), but the PLE version doesn’t appear to include that correction.
Are there any plans to update V-Ray 7 PLE with this fix?
We really appreciate Chaos making V-Ray available through the Personal Learning Edition. An updated build would allow us to move forward with V-Ray 7 without disrupting our students’ learning progression or existing workflows.
Thanks for your attention and continued support of the educational community!
Thanks for the report. Indeed, we should update the PLE versions. I’ll forward the task to the product owner.
Thank you, Aleksandar! I really appreciate your attention and for forwarding this to the product owner. Hopefully, we’ll see an updated PLE version soon.
I look forward to receiving further updates on this matter. Thanks again for your support!
Just so you know: we will release a PLE build with the next V-Ray for Maya update.
Great! Thank you so much!
