I need help setting up 3ds max 2014 and Vray 3 so that what I see in the Vray Frame Buffer is the image I send to my client.
Right now there are discrepancies between the two and its bugging the hell out of me.
The image looks beautiful in the frame buffer but ugly in Photoshop (appears slightly Posterized).
The Image looks perfect in After Effects but when I go to Project Setting > Working Space = “sRGB IEC6966-2.1” and check the “Linearize Working Space” it makes the image chrunch and look Posterized.
I have used Photoshop, Nuke and After Effects and every time I try to encode the image with sRGB colorspace the image Posturizes slightly.
Can some very kind people help me out or point me in the right direction in terms of setting up a rendering pipeline where what I see in the Vray frame buffer is the same as what my client sees? am working for a client at the moment and I need to fix this ASAP.
I opened a support ticket with Chaos Group and they have been extremely helpful on the matter. Thank you Svetlozar Draganov from the Technical Support Department.
First of all to set up a Linear Workflow you have to set Color Mapping Type to Linear Multiply, Gamma equals to 2.2, Mode - Color Mapping Only (no gamma).
Then from Rendering Menu > Gamma Settings: make sure that Enable Gamma checked and set Gamma value to 2.2.
Max 2014 will automatically apply gamma correction to each image depending on its extension - for example JPG images will be automatically gamma corrected when loaded since they have sRGB-profiles but linear-type file formats like EXR/HDR and etc won’t be.
With this setup Vray will load, render and output image in linear-color space which then could be loaded in Nuke and it will appear in the same way as in Vray Frame Buffer.
