v-ray and bongo
When i try to render an animation from bongo out it only renders the first frame and then stops. Not allways though, in the default settings it works fine but in the starterkit settings and a few others it does not work. When i set rhino as the render machine there is no problem.
Is this a bug? Or are Bongo and v-ray not working well together?
Regards,
René
Re: v-ray and bongo
Easy to fix, you must enable “batch rendering” at the global switches. In this mode you can’t edit your model during rendering.
Re: v-ray and bongo
Thanks, that did the trick.
René
