[V-Ray Asset Editor] TypeError: Cannot delete property 'port' of #<Object>
When we start the Asset Editor we get this message:
5/17/2022 6:16:22 PM
Error
[V-Ray Asset Editor] TypeError: Cannot delete property ‘port’ of #<Object> at Object.getSettings (file:///C:/Program%20Files/Chaos%20G…js:101:2113479) at Object.remote (file:///C:/Program%20Files/Chaos%20G…js:101:3078540) at e.Object.keys.reduce.e.<computed> (file:///C:/Program%20Files/Chaos%20G…js:101:2488203) at t.value (file:///C:/Program%20Files/Chaos%20G…js:101:3075280) at file:///C:/Program%20Files/Chaos%20G…js:101:2485948 at Array.every (<anonymous>) at file:///C:/Program%20Files/Chaos%20G…js:101:2485916 at f (file:///C:/Program%20Files/Chaos%20G…js:101:2485551) at Object.ID_4 (file:///C:/Program%20Files/Chaos%20G…js:101:2485876) at e._invokeCallback (file:///C:/Program%20Files/Chaos%20G…js:101:2479987) Promise { <rejected> TypeError: Cannot delete property ‘port’ of #<Object> at Object.getSettings (file:///C:/Program%20Files/Chaos%20G…js:101:2113479) at Object.remote (file:///C:/Program%20Files/Chaos%20G…js:101:3078540) at e.Object.keys.reduce.e.<computed> (file:///C:/Program%20Files/Chaos%20G…js:101:2488203) at t.value (file:///C:/Program%20Files/Chaos%20G…js:101:3075280) at file:///C:/Program%20Files/Chaos%20G…js:101:2485948 at Array.every (<anonymous>) at file:///C:/Program%20Files/Chaos%20G…js:101:2485916 at f (file:///C:/Program%20Files/Chaos%20G…js:101:2485551) at Object.ID_4 (file:///C:/Program%20Files/Chaos%20G…js:101:2485876) at e._invokeCallback (file:///C:/Program%20Files/Chaos%20G…js:101:2479987)
We use
Rhino 7 5.20.05
V-Ray core 5.20.20
V-Ray NeUI 4.2.4
V-Ray AppSDK 3.10.00
Hello, Simon,
Are you able to recall when this error first occurred? Was it right after installing V-Ray or after a specific action was taken?
It seems you have corrupted V-Ray Swarm settings which most likely prevent you from using distributed rendering via the Swarm manager.
There are a couple of workarounds you can try:
  1. Ensure Rhino and V-Ray for Rhino are closed, then delete the following directory: %APPDATA%\Chaos Group\V-Ray for Rhinoceros\vrayneui\Local Storage
  2. Reinstall V-Ray for Rhino using the latest build (v5.20.06) available at Download | My Chaos
Please let me know if this helps!
Kind regards,
Peter
Hello Peter,
Thank you for your message. The procedure works fine. V-ray starts now without error message.
Kind regards,
Simon
