V-Ray Blender 4.5.x Physical Camera Bug
I’m experiencing a problem with V-Ray for Blender: when I enable a physical camera, the framing doesn’t match what’s shown in the Blender viewport. Is this a bug or expected behavior?
I found out what causes this but there is no fix. I enable Physical Camera from the viewport right-click menu and use Set DOF Picker on an object. When I open the VFB it was zooms in. Even after closing the VFB and turning off depth of field, the camera stays zoomed in.
Hi jeremy_bertoldo,
I’ve been running some tests on my end to see if I could catch this, but I haven’t been able to reproduce any shifts in the camera position after enabling the Physical Camera, DOF, and using the Distance picker. Could you record a quick video of your workflow in case I am missing any details? Also, which version of V-Ray are you currently using?
Thank you for getting back to me. I am using V-Ray 7.20.01. For renders from a distance, this does not seem to be much of an issue; however, in macro-level shots it becomes very apparent.
The zoom-in effect can be seen in the second part of the video as proof it is a bug. I copy and paste the camera so that it is in the same position and has the same settings, and I never enable depth of field. You can see that even though they are the same cameras with the same settings, the one that once had depth of field enabled is permanently zoomed in.
Video:bug
Hi jeremy_bertoldo,
I was able to reproduce the issue with a close-up camera and logged it as a bug (VBLD-2277). Thank you for reporting it. We will update you if there is any progress on it.
