V-Ray Camera and IPR
The two don’t play well together. The camera doesn’t maintain the same MAX viewport ratio and auto vertical tilt fails.
Same issue here. Restarting Max solved the problem tho…
Oops, spoke too soon. It’s doing it again…
Yeah, it does not stop and it has done it since R5, I just never said anything.
Hm, I haven’t seen this. Can you post a video and/or share a scene, however simple it is?
You can find similar topic with examples here:
https://forums.chaosgroup.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-problems/1103927-interactive-rendering-and-vraycam-shift-problem
Best,
Andrei
Here is a simple scene. Dropbox
Hi guys, thanks for pointing that out. It’s been reported under VMAX-10803 and our devs will have a look asap. We’ll make sure to keep you updated. For now it appears that stopping and starting again the IPR will match the viewport.
Yes it does but that means reevaluating the entire scene each time…which of course makes the whole IPR thing a bit pointless in this case :slight_smile:
Hi again all,
We improved the release thanks to your quick feedback!
You can re-download the new V-Ray 5 Update 1 installations from our Chaos download page now, the IPR issue should be fixed - do share your feedback.
Please accept our apologies for the inconvenience! Many thanks!
