V-Ray Camera Shift Drag
I have reported this several times over the year. When I create a V-Ray camera, shift+drag to copy, it freezes MAX 100% of the time. I don’t think I ever got a reply or solution.
Just try copy my vray camera here, do not have problem, but my window is window 10
I don’t don’t know, except I have Windows 11. If I remember correctly, it happens when you have Verticle Tilt enabled.
Can report the same issue. The FPS counter goes into a random count loop. Automatic vertical tilt is also enabled.
Yep. I have reported it several times over the year, but I am not sure it made it into any kind of bug list becasue it never got fixed.
Stable nightly builds (Chaos) starting from 22.05.2023 (build number 32098 and later) contain a fix for this issue.
Sorry for the inconvenience.
Yavor
How do you down load the nightly build, I click on it and nothing happens. ?
I think Choas has to give you right to them.
