What are you guys using to view those images on the retail Rift?
The DK2 had a supported software called Capsule, which is not compatible with CV1( yet??).
Cheers for your input ![]()
Ralf
Ralf
Should just be able to use the 360 photos app same as Gear VR.
On Oculus store i beleive.
The photo app does work, but only when the resolution is exactly 18432x1536.
I need to focus a bit more ![]()
thx
I use virtual Desktop. I viewed 24kx2k cube maps with it. So I believe it will work with any res in 6:1 and 12:1(stereo) ratio.
But as well as the photo app, it distorts slightly.
Too bad there’s no newer version of capsule.
