V-Ray Decal Displacement: Negative Displacement Depth Not Working as Expected
Body:
Hi everyone,
I’m having an issue with V-Ray Decal displacement. When I apply a Decal to a flat surface (for example, a road) and use a negative displacement value to create an indentation—such as a puddle—the decal only sinks in slightly. Whether I set the value to -10 or -100, the result appears identical. It looks more like bump mapping than actual geometric displacement.
In a previous version of V-Ray, the same settings produced the depth I needed. I commonly use this workflow to add surface details like puddles. In the current version, however, the effect is no longer usable.
Is this a known issue? Has the displacement behavior for V-Ray Decal been changed? Any advice on how to restore deep negative displacement would be greatly appreciated.
Thank you.
I’ve tried many methods but none of them worked. However, it works in the lower version. Could it be a problem with the version? Will it be solved in the future? Or is there any way to solve it now? I want to make a ground water pool, but the current one that’s sunken is really not acceptable.
Hi, we will check the case. Meanwhile, please share this scene with us.
2024(2024).zip (6.2 MB)
Hello, I have uploaded my illustration file. In the previous version, I was able to create a displacement effect to make the pattern recess on the surface. But now, this is no longer possible. I don’t know what’s going on. Could it be that the operation mode has changed? I hope to receive your guidance. I’m Chinese and I used a translation software. The expression might not be very clear.
Try adding a VRayDisplacementMod on the Plane002 object, set Amount = 1, Texmap min = -9999, and Texmap max = 9999. This way it should work. Returning your scene with the adjustments, I’ve set the Displacement map value in the material to -1000 for better visibility.
adjusted_2024.7z (125.8 KB)
Thank you for the solution.
