V-Ray denoiser flickering during IPR
Hello!
I know that the V-Ray Denoiser is supposed to be used in production, but is it expected to have this much flickering when it is running in the IPR?
It might be a particular issue of this scene, because I don’t remember experiencing this before…
File attached in case you want to check.
Blender 5.2.2 LTS / V-Ray 7.40.01, rev 663 Sep 30
Blend file attached.
teste.zip (620.0 KB)
If I remember, since IPR runs with Progressive sampler, the denoiser is constantly trying to clean the preview after each pass, right? If this is the case, then it is ok
Hello @julio_arvellos You are correct that the denoiser is constantly trying to clean the preview.
Are you able to reproduce this with a new, simple scene as well?
Hi, Viktor!
Yes, it happens in new scenes as well
Hi @julio_arvellos While this is a behavior that I would expect, I am currently unable to reproduce it in a new scene.
In your scene, once I remove your geometry and add a cube, the flickering stops.
We are currently looking into it and I contact you if I have any information to share.
I think I know why it is happening. In my other post I mentioned the difference in IPR vs VFB denoise speed ( IPR runs faster in the Viewport than VFB - #2 by bozhidar_ivanov ), and bozhidar suggested to change the Image Effects Update Freq. to 100.
If you set this to 100 and re-run the IPR, the flickering will start. If you reduce it back to 10 (the default) this is likely to not happen.
But after some testing in a new scene I noticed something.
  1. Img Effects Up. Freq to 100 > flickering starts after a few passes
  2. Img Effects Up. Freq. lower than 100 > flickering starts after a few hundred passes (test with reflective/refractive material so IPR will run longer) and you will se some black lines, until rendering stops.
But again, I think this is kind of expected as VRay denoiser is supposed to be used for production, I just not sure what exactly triggers the flickering. Maybe the amount of render channels used by VRay (diff, reflect, refract etc.)? Would be good to understand it.
Hi, @julio_arvellos!
The flickering happens because, during interactive rendering, the frame buffer sometimes redraws while the V-Ray denoiser is still rebuilding the denoised image, so you briefly see an unfinished one. Added extra channels don’t cause the issue directly, they can only slow down the denoiser, which makes it easier to catch the frame buffer mid-update.
