V-Ray Dirt issue
Is anyone else having issue with V-Ray Dirt in V-Ray 6? Using version 5 it was working fine but since updating to 6 the same scenes are not rendering V-Ray Dirt,
And just to confirm its not my material setup, I have opened 3DR&B Museum Scene which uses Dirt as a blend for the concrete floor but it only renders the base material not the other layers blended with V-Ray Dirt.
Hello @jon_leeke ,
Can you please let me know if you are rendering with V-Ray or V-Ray GPU? Thanks.
I’m using V-Ray GPU
Hello @jon_leeke ,
That’s what I thought. There seems to be a difference between GPU and CPU when the list of “affected by” is empty and the mode is “Include”. If you want to render a dirt map with the GPU, you will need to change the type of include/exclude list as shown here. This is logged in our system and we will let you know if we have any updates. Thanks.
Ok , yes that fixes it. Thank you
