I am unable to render even one frame, I tried it on 3 computers now,
whenever I switch to GPU rendering it takes forever to render one frame and then Max crashes before it finishes the frame, no matter how big the file size. What do I do?
I am using nvidia geforce gtx 1050, Intel Core i7, CPU @ 2.20GHz
Does this happen on an empty scene? Are you getting any warnings/error messages, and if so - please do share a log.
Would it be possible to forward the crash dump files so we can have a look? Also try to install the latest recommended GPU drivers to see if this will help.
I’m having exactly the same result when I try to render GPU vs CPU. I’m using an RTX 2080 ti as my GPU.
What I’m finding is that when I initially build a file it will render with the GPU, but that when I try to do a production render using CPU it starts to set up the render then just quits. I haven’t looked at the memory issue that some have as I have 256 Gigs of RAM. When I watch the log window under a CPU render, there are no warnings or error messages.
But here is the thing that stumps me. When I merge the file into a freshly reset file, it renders correctly with CPU usage. I’m not sure what setting I may be using that would cause this error, and frankly I don’t think I’m doing anything exotic.
A separate issue is that when I switch between CPU/GPU I get wildly different results. The GPU version is blown out and useless. I wouldn’t think that the difference would be that profound, as it isn’t using any other render software that I use.
I hope that someone can enlighten me. Thank you in advance.
