Can not Find the reason for the error in console. Please Help me out Urgently.
Link of file https://drive.google.com/file/d/1FgJ…ew?usp=sharing
V-Ray 5 For Cinema-4D, Hotfix 2 (v5.00.44 From March 25,2021)
System:
Ryzen 5 1400
RTX 2060
Driver: 27.21.14.6192
With the settings you have, I have such an error.
When I change to CUDA it starts rendering, but after a while Cinema crashes end closes.
It is most likely the missing texture.
Additionally, when I changed the wood texture path from pressets to local, the GPU render started to work.
Similar problems with GPU were described here:
https://forums.chaosgroup.com/forum/…brid-rendering
Currently, GPU rendering requires special care as it has great problems with texture paths.
Cpu rendering works normally.
I am sending a scene with corrected paths:
Thanks For The Help. Appreciate It.
