V-Ray for 3ds Max and USD
As some of you know, Autodesk is working on USD support for 3ds Max. They have kindly provided a SDK for us to hook up everything V-Ray related. So far things like V-Ray materials, textures, displacement and lights should be properly exported to USD.
Here you can find builds capable of exporting V-Ray data to USD - https://drive.google.com/drive/folde…y3?usp=sharing
Few notes for the shared builds:
  • they will work only with USD3dsMax version 0.3.2.1980 (public beta available from Autodesk)
  • these builds are meant only for testing, they might be unstable
  • as of today, we’ve added only export functionality; rendering USD data still happens only through the VRayScene node; 3ds Max USD Stage node will not render V-Ray specific data
  • the exported USD files should be properly consumed by V-Ray for Maya and Houdini
  • a list with the things that are not exported to USD:
    • V-Ray object properties
    • VRayClipper
    • VRayDecal
    • VRayFur
    • VRayEnmeshMod
    • Chaos Scatter
    • VRayVolumeGrid
  • when exporting make sure you’ve checked these:
Is USD3dsMax version 0.3.2.1980 publicly distributed? i can’t find it.
3dsMax USD from Autodesk Desktop app or Autodesk account looks like 0.3.0.
I got mine from the AD beta website. I’ll share here as soon as there is more info.
There are new V-Ray builds in the shared folder that support the older USD3dsMax versions.
Thanks for the old USD3dsMax support. I was able to test it.
User-Defined Properties tag and UVTile tag of VRayBitmapTex are not supported?
Maya’s USD Loader and V-Ray Scene Loder(USD) does not handle these correctly.
However, the V-Ray 3dsMax vrscene object’s USD Loader seems to correctly handle the VRayBitmap User-Defined Properties Tag from the USD.
@matanov Would it be possible to share that Autodesk USD plugin or a link? I cannot access it from my Autodesk Beta Forum Account. Or are your latest installers from the dropbox link compatible with USD 0.3.0xx release from Autodesk?
I will most probably break some rule if I do that. Better contact the Autodesk guys to check why you don’t see the files from your account.
Thank you @matanov , I will work with the 0.3.0 release then.
Can you tell me if i need to prepare or export my file textures for any vray material before USD export? Or will texture paths remain relative during the vray material export to .USD ? Can or should textures be “packed” into the .USD file, or will texture maps need to be right next to the .USD?
The Max exporter writes only full asset paths for now. You can export to .usda and then change the paths manually if needed.
The info in this thread is now kind of old. We’ve release official support in V-Ray 6.1 and here is the docs page - V-Ray for 3ds Max
hi. not sure where else to ask this - should the usd exporter be creating material files from vray materials on export?
i’m using the latest version of the exporter (v0.4.0.2282)
Hi. Currently 3ds Max exports monolithic USD files, containing both materials and geometry.
If you have V-Ray materials that are not exported, please first check if you selected the correct Plug-in Configuration in the export window.
