Hello everyone,
V-Ray 7 for Blender Update 4.1 is out now.
In this release we introduce rendering and relighting of Gaussian Splats, Chaos Scatter (available as an additional addon with V-Ray) as well as Live Link to Chaos Vantage for realtime rendering and previews.
For best interoperability with other V-Ray integrations like 3DS Max, Maya, Cinema 4D, etc we’ve added an option to import V-Ray Scene Files (.vrscene) as native objects in Blender. This means that any material or object from other V-Ray integrations can now be transferred in V-Ray for Blender as long as there is an alternative in Blender for it.
The tools in V-Ray for Blender are also growing up with two new tools - The Material Manager and the V-Ray Object Lister.
Changes and new features apply for both the Community Edition and the Commercial Edition of V-Ray for Blender.
Download the latest build from our website and check the Documentation page for more information and resources.
Full changelog:
New features
Introduce Chaos Scatter in V-Ray for Blender (needs to be enabled as addon)
Introduce Live link to Chaos Vantage for realtime preview and rendering
Implement rendering and relighting of Gaussian splats
Introduce V-Ray Object Lister
Introduce V-Ray Material Manager
Import V-Ray Scene (.vrscene) files as native objects in Blender
Add V-Ray Infinite Plane geometry object
Ability to add utility textures and bitmaps from the Material tab instead of the Node editor
Modified features
Add Chaos Scatter Surface Color texture
Add Out of Frustum subdivision control
Add an option to highlight selections in object selectors in the viewport
Add max_velocity_last_frame in the Velocity render element
Add more control for Toon outlines
Add quality presets for the V-Ray Sampler
Add support for Chaos Cosmos assets sets
Add support for Custom per instance user data for Geometry Nodes
Add support for material thumbnails
Add support for rendering and converting Cycles Principled Hair, Vector Math, Float Curve and Map Range Cycles nodes
Add a shadow catcher revert option in the F3 menu
Add support for rendering and converting Cycles worlds
Add a way to create LightMix and Denoiser in the World tree
Add a button in the LightSelect render channel that leads to the LPE builder
Add the rest of the missing Raw filter render channels
Add the option to include the Rest channel when saving VRayLightMix to file
Connect V-Ray material bump when dragging link on top of the Bump rollout socket
Convert the Cycles Thin Wall introduced in Blender 5.2
Draw the curve directly in the Remap texture node
Fix “Back to Beauty” not showing up in the VFB when all beauty elements are present
Export only the geometry attributes that are used during shading
Import V-Ray Luminaires from Cosmos lights
Improve UV-only support when UVW Randomizer is used
Improve V-Ray Curvature user interface
Improve material preview performance
Improve naming of assets imported from Cosmos
Improve the arrangement of nodes when importing assets or using ‘Arrange Tree’ option in the Node Wrangler
Improve the conversion of Cycles Principled materials
Keep displacement texture link when changing displacement type
Show a status during V-Ray GPU kernels compilation
Speed up hair export for particle systems and curves
Use UVW Projection with texture transform for converting the Cycles Generated coordinates node
Use incremental updates for interactive object visibility and referenced objects
Velocity render element should work without enabling Motion Blur
Bug fixes
A frame step of 0 raises an uncaught ValueError and the render never starts
Animation .vrscene export does not restore current frame
Blender adjust light operators don’t work
Blender crashes when trying to render the 2.90 Blender splash art scene
Camera operators raise an error when invoked outside the 3D viewport
Cannot change shape of IES light
Chaos Cosmos does not register in Blender on multi-user systems
Clicking Material Preview while in Viewport Rendering mode resets to viewport shading
Converted Cycles gradient ramp doesn’t work with procedural textures on GPU
Crash in the server if a connection is closed too fast
Cursor moves to the center of the screen when asked to overwrite output image
Custom frames list keeps duplicates and overlaps, so frames render more than once
Cycles Math node “Inverse Square Root” converts to 1-sqrt(x) instead of 1/sqrt(x)
Cycles Principled specular renders at half brightness in V-Ray
Disappearing geometry when using an instanced decal
Dropping a .vrmesh into the viewport cannot be undone
During viewport rendering with the Blender 4.5 splash scene, instanced collections disappear when the user changes the object selection
Empty undos created when trying to remove the last socket in containers
Exceptions after deleting multiple objects used in a single object selector
Exception when exporting particle hair in the Blender 2.91 splash art scene
Export errors in the Blender 5.1 splash art scene
File overwrite check not performed when production job is started from VFB
Film Speed not grayed out when Exposure Value is used in V-Ray Physical Camera
Frame 0 is dropped from the render sequence with animated view layer
Rename V-Ray Fur’s “Gravity Variation” property to “Length Variation”
Increase V-Ray Sun’s Cloud offset soft limits
Light Mix “Apply to scene” confirmation popup is missing
Light Select arrives with an empty Lights list
Limit Light material minimum color multiplier to 0
Loading the V-Ray add-on might break the HIP integration in Blender
“Make Shadow Catcher” command does not enable Affect Alpha
Merged objects and materials from other Blender files are not upgraded
Minor differences in Blender 5.2 compositing
Objects disappear when two of them use different Motion Blur sample overrides
Render Settings > Common > Rendering quick toggles cannot be undone
Render region resets on interactive rendering
Rendering animation never finishing when switching between cameras with motion blur
Rendering a single frame with Motion Blur never finishes
Remove the deprecated Precision parameter in 2D displacement
Rolling Shutter is not included in the motion blur export interval
Start Production Render from top menu does not respect render settings
Starting an interactive render refreshes material previews
Stopping caustics during interactive rendering doesn’t work
Transferring 0 intensity from Light Mix to scene breaks subsequent intensity updates
Undoing collapses any opened rollouts in the V-Ray node editor
V-Ray Triplanar texture is missing the random by user attribute parameter
V-Ray Volume Toon causes artefacts with geometry mesh converted from a curve
V-Ray Server crashes after wake from sleep on Mac OS
VFB layers are not loaded correctly when changing scenes
VRayZmqServer doesn’t quit properly on macOS
VRscan relinking from the Object Lister doesn’t work
Viewport status messages are not filtered based on preferences log level
Wrong Checker scale when converting from Cycles
Wrong hair export in a specific scene
Wrong material export in a geometry nodes scene
Wrong render result given to Blender when VFB render region is used
V-Ray Installer
Importing Blender preferences into a new version of Blender breaks the installation process
Add a link to the docs in the Directories page of the Installer
