Hello, I’m a Vray for Rhino newbie.
I’m currently trying to create a water surface that allows sunlight to go through so that the room inside the space has a caustic effect.
However, it’s very frustrating that there isn’t a currently updated version of the tutorial for Rhino.
1. Fog Multiplier
I keep seeing ‘Fog Multiplier,’ which seems as it used to be in the old version.
Where did it go? I only see ‘Depth’ under ‘Fog Color’
Also, what would be the relationship between the old settings of ‘Fog Multiplier’ stuff and the new version’s ‘depth’
The tutorials say the ‘Fog Multiplier’ has to be small while a change of ‘Depth’ doesn’t really do anything unless it’s either 1 or 0.
I hope I could adjust this more accurately, not on or off
The tutorials I watched are:
- https://www.youtube.com/watch?v=vNJhJQQpo8c
- https://www.youtube.com/watch?v=f8X2V\_NtrSs
The values of the ‘Fog Multiplier’ are small in the tutorial
I tried to make the value of ‘Depth’ small to see if the ‘Fog Multiplier’ became ‘Depth’ or whatever
Value 1 and 0.003 are the same while 0 shows full transparency
2. Photon Mapping
I finally saw a tutorial with a ‘depth’ setting. This person turned on ‘Depth’ up to 50cm. (I don’t know higher value makes it a little more transparent while the smaller number just makes the water opaque.)
However, as he moves to the render setting, I do not see my ‘Photon Mapping Caustics’ setting.
I assume I could use the ‘Caustics.’ However, when I turn on, I can’t change ‘Max Photons’ and ‘Max Density’
Q. How do I turn on the photon setting??
The tutorial I watched is:
- https://www.youtube.com/watch?v=vqerpiJuOv0
Please someone save this poor newbie.
Thank you
