Ok so this issue randomly came up. At first, my materials were not rendering in the Asset Editor- like I was not able to see the material preview. This is an issue that others have had as I’ve seen in forums. I completely reinstalled Windows because of this and I just wanted to clean up a bit. I thought that the problem would definately be resolved, but now it is much worse. When I drag a material from the Library, they don’t get added to the list of Materials in the scene. If I try to add a Generic Material, nothing happens. Also, when I click Render, nothing happens at all.
Hello, @akashi1 ,
This sounds like a very serious issue!
We can offer you direct assistance via TeamViewer to investigate and resolve this problem in a minimal amount of time.
Please submit a support request at https://support.chaos.com/hc/en-us/requests/new and mention this forum thread in the message as well as the versions of V-Ray and Rhino you use. We can arrange all further details using that channel of communication.
Kind regards,
Peter
Just sent, thank you
Thank you, @akashi1 .
I have just answered you there.
Let’s get this solved!
To inform the community - it was a license issue, which was hindering V-Ray to work smoothly.
If you experience something similar, please open http://localhost:30304/#/ and check are your licenses (Interface & Render) used even before starting the host platform.
In this case the Render node license was borrowed on another PC.
Contact us again if you are experiencing any difficulties.
Enjoy V-Ray!
