From time to time we end up with Maya windows off-screen due to monitor order/orientation change. This is a 100 year old problem here, without a solid solution… until, maybe now
This piece of MEL code successfully finds all Maya windows and moves them to coordinates 0,0 even in a multi-monitor setup: for ($window in lsUI -windows) { window -e -tlc 0 0 $window ; }
However, it doesn’t manage to find the V-Ray framebuffer. Can the framebuffer be moved too somehow?
Credit for that piece of MEL goes to Keith Rogers.
The VFB is a Qt window; it is also registered as a dockable window in Maya. I don’t know how the lsUI command works; it is possible that it only handles windows created by Maya itself. You might have to use Qt-specific code to find the VFB.
I thought this seemed odd …because my Qt windows move with that code but not the V-Ray 2.x frame buffer. Turns out that the V-Ray 3 frame buffer does indeed move with that code. But the V-Ray 2.x frame buffer does not.
VFB in 3.0 is now a Maya panel, so it can be docked.
In 2.0 it is just a QT window created manually (as Vlado mentioned), so the Maya APIs don’t know much about it.
