V-Ray GPU does not support Opaciy Map connection from filenode's Out Transparency?
V-Ray GPU does not support Opaciy Map connection from filenode’s Out Transparency?
If no, it is a very big support defect.
The user has to change the file configuration with CPU and GPU.
tested on 3.60.04
We’ll check it out.
Thanks for the report.
We fixed it internally for when the nightlies will be back and for the next release.
If you need this, we can port it in 3.6 so you can use it (way) sooner?
Best,
Blago.
Thank you.
I will check Nightlies
I will let you know when it is in the nightlies.
Best,
Blago.
Should be fine in the latest stable nightly. If you don’t have access to those, please mail to support@chaosgroup.com with link to this thread and they will give you.
Sorry for the troubles,
Best,
Blago.
Thank you for information.
I already have access to Nightlies.
