V-Ray has a bug when using millimeters as the unit of measurement
I remember submitting a support ticket about this, but it seems you didn’t take it seriously.
Hi @binjun_wu Are you able to reproduce this in a simple scene?
What version of V-Ray and Blender are you using?
Hi, we fixed a bunch of scene scale problems including this one recently, it should be in the next release which is coming out really soon.
This issue still hasn’t been fixed. After importing a VRScene into Blender, the results are completely different when using the CPU versus the GPU, whereas switching between CPU and GPU in 3ds Max produces the same results. These seemingly minor issues have the biggest impact on the user experience
. I hope you can fix this as soon as possible.
I’m using Blender 5.2 with V-Ray 7.4.03. You should be able to reproduce this issue easily.
You seem to be using a slightly older version in the screenshots. There’s the banner that update 7.40.03 is available for installation, however, the problems with millimeters should have been fixed in 7.40.02. The CPU and GPU difference look like a separate problem, so could you sends either a .vrscene or a .blend file so we can investigate it? You can also use support.chaos.com if you don’t want to share the scene here.
Okay, I’ve submitted a support ticket. I’ve also tested version 7.40.03.
The bump values on the models imported into Blender are all very high. I haven’t used V-Ray for 3ds Max much, so I’m not sure how it works, but everything looks normal in Max despite the high bump values. Switching between CPU and GPU also gives the same results there. In Blender, however, you have to reduce the bump values by a factor of 1,000 when using GPU rendering.
