Hi guys
Is this something that happens only to me or RE Light Select does not support IES V-Ray lights???
Regards
Ledian
Hi guys
Regards
Ledian
Works for me on a simple test; if you have a scene where it doesn’t maybe you can post here or send it to support@chaosgroup.com?
Hi Vlado
Thank you for the reply
Here’s the scene
Dropbox - Error - Simplify your life.
You can see the grouped selection does not appear in RE at all.
Regards
Ledian
My apologies for not mentioning the Render Engine (V-Ray RT GPU 3.60.04)
Regards
Ledian
Ledian, you have 3 threads for the same issue.
1. You didn’t mentioned anywhere in the posts that you are grouping the lights. As a matter of fact you are grouping them together with their targets, which is causing the issue. Grouping only the lights and picking that group will work as expected.
2. The speed of processing your issue is not multiplied by the number of threads opened for it.
Hi Peter,
Thank you, good to know!
Regards,
Ledian
Just out of curiosity would the grouping of lights have other potential scene errors in general or just in this specific case ?
thanks
anthonyh
Actually Ledian’s case was even more complicated - the group was made from VRayIES lights as child objects of their targets.
