v-ray layered shader
Hi there is possible to add names to layers?. It could be very interesting to know the steps for the shader :wink:
thanks
best
nuno
Hi nunomatos​,
It depends on whether you are referring to VRayLayered or Layered Node. If you are using VRayLayered texture, then you cannot assign names to the layers. However, this is possible in the Layered Node if you double-click on the layer. (video example)
