V-Ray License Server Issues
Hi all,
We have licenses for V-Ray 2.0 and 3.0 for Maya. Previously, running the license server on an Unbuntu 10.04 machine with 2.0, everything was smooth. However, since we’ve updated our dongle with the 3.0 license, the license server randomly dies at midnight and will not come back up until I reset it in command line (using the init.d script). This is a problem, since we often render bigger shots overnight, and coming in in the morning to failed renders due to unobtained licenses (since the server is down) has been causing problems. We’ve upgraded our WIBU key to 6.20 and the license server is ver. 3.0 protocol ver. 7 and no joy. Does anyone have any idea?
You are using an old Wibukey driver and most probably this cause the issue.
Please try to update to the latest Wibukey driver 6.32 which could be downloaded from the “WibuKey for Users” section from the link bellow:
Please note that before installing the new driver you need to first remove the old one.
Please let us know if you need any further assistance on that regard.
