V-Ray Light Lister corrupted display
Has anyone experienced this issue? In The V-Ray Light Lister window the list displays overlapping lights.
Using V-Ray 6 update 1 (6.10.04 build 0000) with 3ds max 2023.3.3, three monitors, 2 x 1920x1200 and a 4K monitor. Nvidia RTX3080 with the latest drivers installed.
Hi, thanks for posting. This happens if you have a different scaling than 100% in your windows settings.
We have this issue logged under VMAX-7921. I will add your thread to it and raise the priority.
Not exactly: this happens if the scaling is arbitrary, instead of being one of the set offered by Windows via dropdown.
I wrote the “fix” for the other scalings, and they have all been tested and shown to work (some better than others, admittedly.).
As a fix, therefore, simply pick one of the offered scaling values (125, 175, etc).
Arbitrary scaling can’t be supported by Maxscript, so no fix will be forthcoming.
We’ll have a new lightlister done soon enough, however.
请问 vray 6 for max 2020 的灯光列表脚本放在 max 中的位置吗?
