I noticed different render result when rendering with ActivShade and Production V-ray GPU or CPU.
I have 3 regular and one dome light with HDR inside the scene. From what I can tell only Dome light is affecting the scene whereas regular lights don’t.
When I start rendering a first few passes show the lights (i turned them to red color so i can see the difference) but after some passes they disappear.
I checked everything and i think it should be ok with the settings. Basically they are default settings except the power (20-100) and color.
First image is first pass, and the second one is after.
Third image is Activ shade + Vray RT GPU
Do you know what could be causing a problem here?
What version of V-Ray are you currently using? Is it possible to send us a simple test scene for investigation?
