V-Ray Material Mapping
Status: pending
Would love the ability to move to vray when necessary but still have all assets, materials, lights and cameras work in Enscape, which is the preferred day to day environment.
Submitted on AHA Ideas by matt (ENSCAPE-I-439).
very high, since you create models with v-ray properties and share them via Enscape
Submitted on AHA Ideas by mario.
when I jump between test renders and final renders
Submitted on AHA Ideas by msm.
The bi-directional workflow will be crucial for V-Ray users like myself, my organisation and the people that I teach. This is exciting for two reasons from my POV:
  • Design & material development in Enscape before transitioning into V-Ray is well publicised and makes for a more seamless visualisation process.
  • Going the other way from V-Ray to Enscape would facilitate the creation of animation, virtual tours, and all of the other areas which Enscape outperforms V-Ray. I look forward to creating our animation in Enscape once the bi-directional workflow has been enhanced.
Submitted on AHA Ideas by dan.
We’re an architecture firm. We do all preliminary design in Enscape and would switch to V-Ray in a later stage of the project.
Enscape is great for producing fast results but V-Ray has by far the better material library. So it would be great to use the V-Ray assets in Enscape and it would boost both products a lot
Submitted on AHA Ideas by tibor.
Working in the tv design industry sometimes/often I have to revise my drawings quickly after they are rendered and don’t want to have to reapply textures and lighting twice, often I will provide 1 or two high quality renders and then a series of smaller and more detailed views that do not need the quality of vary
Submitted on AHA Ideas by danbetteridge.
to go back and forth between enscape and vray would be perfect
Submitted on AHA Ideas by timo.
Submitted on AHA Ideas by 82313633.
sometimes all I need is a fast image to sell the project and Enscape is very good and fast at it.and then when I need to produce more high end images, I always use vray. But there is always a back and forth, and come back to Enscape and so on.
Submitted on AHA Ideas by aniela_annia.
For certain projects I purchase assets from Turbosquid and the like.
Many of these models have V-Ray materials and mapping already applied.
It would be great to take advantage of those in Enscape.
Submitted on AHA Ideas by pjmuller.
I use VRAY objects to get higher quality renders and hoped to use enscape to do walkthroghs with clients. The Vray chaos cosmos librays is much better than the enscape one. However I am forced to either use enscape and have a worse final rendering or swap out materials in the end myself. This is time consuming and not really worth it to me.
Submitted on AHA Ideas by mkorn.
We have different works that requires differents workflows. Once we know Enscape is faster than V-Ray and Vray is superior in quality (in general terms) than Enscape, can choose between then for each ocasion without settings loose is a dream!
Submitted on AHA Ideas by murilo.oec.
This would open up a lot of possibilities related to materials. Currently the enscape material library can be limiting at times. There are a vast resources for V-ray
Submitted on AHA Ideas by leonardo.
we have a lot of 3d data with vray materials, we want to use in enscape
Submitted on AHA Ideas.
As a visualizer it is critical to have the opportunity to translate more realistic renders in V-ray; however, the vast majority of the time, the models are step up to work mainly on Escape, creating a large additional job to curate materials and other elements from enscape to adapt to v-Ray. Having a more seamless transition between both, will create a faster path to better quality renders in less time.
Submitted on AHA Ideas by jose.gonzalez.
my workflow: creation phase in enscape, for quick decisions with the team > final images in v-ray for marketing > videos in enscape
Submitted on AHA Ideas by henriquenunes.
This will be useful on a regular basis. We may be producing high quality 2D renders in Vray then switching back to Enscape for VR walkthroughs or testing design options.
Submitted on AHA Ideas by jwaterman.
Having access to V-ray materials within Enscape would be great!
Submitted on AHA Ideas by seven_plus_7.
what to make the rendering look better
Submitted on AHA Ideas by spirale.
the main factor or a gap between realism and photo realism is ray tracing of artificial lights
thats the realism boost vray can give to enscape scene.
these worflow really matters!
Hope it would be a “one click” action to have a “Vray result”
(within Vray or within Enscape)
