V-Ray Materials
It is really screwing me on deadlines. I apply a UVW Map and it ignores it at render time.
Weird…any specific material I can try here?
Oh, I see what you mean. It is only those which have a triplanar texture, which overrides the uvw modifier as the triplanar is the mapping source :slight_smile:
Well it could be something different but that’s what I observe as one reason.
Bobby, could you send me a little piece which is misbehaving?
The geo and the shader?
Here is a render. The base has some black tile (first images) from the library and the fascia (second images) has wood from the library, both rendered in the wrong direction. I double-checked and the mapping is correct.
Could you send me just the two geometry bits as max files (i.e. select, then “save selected”), with their associated materials?
Yes, of course. When I go back into the project I’ll save just those two elements and send it over.
