V-Ray Max 52022 install error
I got the following error when installing V-Ray Max 5.2: This App can’t run on Your PC. Any idea what’s causing this?
Hello JuhaHo,
Please make sure to download V-Ray on your local machine and install it instead of run the installation from a network/shared location and let me know if that helped you install V-Ray?
Thank you.
Thank Stefan,
I normally copy install files to network drive to make sure I use the same version. However I copied the file to the local HD and installing from there, it was successful.
Br. Juha H
I just got the same error after installing from the network. It pops up at the very end of installation. I copied the installer locally to computer and reinstalled it and didn’t get the error this time. Odd that it would matter where it’s installing from. Never happened with previous installers.
