I think this means that the negative values are being clipped off. There is a few things you can check. In your displacement where the clipping bounds are set to auto, can you see if you set them to explicit and set the value to be -1/1 or whatever your highest / lowest displacement is. If that doesn’t work, check if there is allow shader negative color checked in misc ui, in render globals.
