V-Ray Next and V-Ray 3.6 compatibility
I was under the impression that V-Ray Next supported V-Ray 3.x scenes via DR.
When a job is sent from a workstation running v-ray 3.x the PC’s running v-ray next doesn’t jump in. The PC’s with v-ray next has the workstation version (not rendernode). But when I look via localhost:30304 I see that each workstation with v-ray next also has a rendernode available.
Sooner or later we are migrating all workstations to v-ray next. Until then I thought we could make use of the extra power from our workstations with v-ray next.
The licenses are compatible but not the installation and the rendering itself. You need to install the same V-Ray version on all machines to render with DR.
Yavor
OK - thanks for info Yavor. :slight_smile:
