V-Ray Next App SDK 4.30.01 Released
V-Ray Next App SDK 4.30.01 is now available for download.
(if you don’t have access, request it here: V-Ray App SDK – V-Ray App SDK for Developers | Chaos)
This release includes an upgrade to the latest version of V-Ray Next, plus many improvements and fixes (full Release Notes are below).
Please, update and let us know what you think!
Regards,
V-Ray App SDK Team
RELEASE NOTES - V-Ray Next App SDK 4.30.01
Highlights
  • VRayRenderer is now thread-safe
  • Added plugin categories and a new plugin categorization API
  • Added new Optix (RTX) render modes (interactive and production)
  • Added support for Node.js v.12
  • Added support for Electron v.5 and v.6
New features
  • Added new functions to manage the Optix devices: VRayRenderer.getComputeDevicesOptix() and VRayRenderer.setComputeDevicesOptix()
  • Added bucketReadyHasBuffer and progressiveImageUpdateHasBuffer properties to VRayRenderer to control if VRayImage instances are to be received in OnProgressiveImageUpdated and OnBucketReady event handlers
  • Added VRayRenderer.setBitmapCache(bool) to control if bitmap textures are to bе stored in memory and not unloaded and reloaded again on the next render
  • Added Plugin.getIntegerID() to allow easier caching of plugin instances in maps, etc.
  • Added examples for creating triangle meshes (trimesh); made numerous example updates
  • Updated ScannedMaterialParams struct with new members and features
Bug fixes
  • Fixed low CPU utilization during light cache calculation
  • RenderView.use_scene_offset is no longer forced to 0 if the user has explicitly set it
  • Fixed a bug where a change in the name of a plugin instance read from a .vrscene file removes all references to it from plugins in the .vrscene file
  • Fixed a bug where geometry preview of vrproxy (in the ScenePreview API) was wrong with more than one object in the file
  • Fixed a bug which caused auto exposure and auto white balance to return 0 in productionCuda and productionOptix render modes
  • Mouse+keyboard camera movement inside the VFB window in interactive mode now works correctly with different current frames / at different times
  • [.Net] The binding is now compatible with strongly named assemblies
  • Added the missing pickPlugins() method
  • [Python/macOS] Fixed module loading issues on macOS
