V-Ray Next Update 3 - VFB popping up on wrong screen
Running V-Ray Next Update 3 in 3ds max 2018 here (with two monitors).
When I open a scene and hit render, the VFB will pop up on my left monitor - instead of the right one (which is my default position) for the VFB.
When I move the VFB window to my second screen and close it and hit render again, it will pop up where I left it. But when I close max and open the same scene immediately, it will revert to the left (wrong) monitor again.
Is there some place that I can override the default position? This is a bit annoying - and it worked better (for me) in the earlier versions.
Thank you for your feedback. It’s a known issue which has already been logged (bug tracker id: VMAX-9143) and it’s in our developers to-do list.
Best,
Philip
Sounds good - thanks!
Bump. This one never got fixed.
