I’m not sure if it’s a bug, just not supported or something else but while V-Ray renders some Enscape assets from it’s library it seems not to render custom assets I put in Enscapes library as well as external linked skp models which are placed in the scene using Enscape.
I’m not sure if there is a way to work around it or already an update in the making supporting both. I especially converted some models I needed to Enscape assets since I supposed Enscape > V-Ray should work pretty well.
Custom Enscape assets should work without any limitations.
I can always provide you with a sample seen but I noticed this answer from you on a different thread
So I searched for the log file and I think it’s actually the same issue as Ted encountered especially if you look at the down right log file part of my screenshot.
The location of my custom assets is *E:\Documents\Enscape\custom assets* where **E:\Documents\** is actually the ‘My Documents’ folder but I don’t like it on C for backup reasons.
That custom asset directory you only set once, the first time when you create a custom asset in Enscape and the value is stored in CustomAssetEditorSettings.json located here C:\Users\<user name>\AppData\Local\Enscape. {"ProjectDirectory":"E:\\Documents\\Enscape\\custom assets","OutputDirectory":"E:\\Documents\\Enscape\\custom assets"}
Maybe V-Ray can just check for that specific OutputDirectory value in the Enscape file and a lot of it is solved (or I might think to straight forward )
I’m just testing/playing a bit and let me know if you still can use some example but I think it’s just a path-thing after digging some more.
We are doing that and that is what bothers me.
We were able to reproduce the missing custom assets scenario only once here in the office and it was with a beta version of Enscape.
After the colleague switched to the official Enscape version all was solved.
We are continuing to investigate…
Well that’s annoying. I tried some things to trick it a bit by not having the model/json in a separate folder and even creating zip + json and putting it at the place for the normal assets. Also copied some over to the maybe default C:/user/username/documents folder but all without luck.
If there’s something I can try to help you guys a bit let me know!
