You know how on real cameras you can choose aperture and shutter priority and the f-stops or shutter speed will adjust based on the settings?
Is there such a way to have that automatically done with the Physical Camera settings (you change the shutter speed and the f-stop adjusts and vice versa)?
Hello matte !
You try it with EV ??
Exposure Value (EV) – Uses the Exposure value to control image brightness. Grays out the ISO parameter and uses Shutter speed and F-number values only for Motion Blur and Depth of field respectively.
Exposure value – Controls the exposure value when the Exposure Value (EV) option is selected. Higher values make the render darker, whereas lower values make the render brighter.
now you can change the f stops or number or shutter speed but this not affect to exposure !!
Interesting. Thanks Carlos!
