We are working on a project where we are using V-Ray MeshProxy’s to render alembic particle caches from Houdini. We did several tests and it all worked great!! very nice feature
Now we are rendering several production scenes and we are finding that chunks of the particles are not being rendered on certain frames, and we can’t find a fix.
If you isolate the proxy it renders correct or if you switch motion blur off then it renders with the environment correct.
Anyone having similar issues? Is there anything we can do to fix this? Thanks for help!
It would be best to get me a scene to vlado@chaosgroup.com so that we can debug it to see what’s wrong. It might be something in the cache file itself, but it’s hard to say without looking at it.
Also, a more reliable way to approach this could be to convert the Alembic caches to .vrmesh files using the ply2vrmesh tool.
I’m trying to setup a simple scene as these caches are massive, but I’ve been unable to re-create the error. I will try and isolate a frame so I can send it to you.
I have also found that its only happening when I have multiple proxy’s in the scene.
If I convert to a .vrmesh will the particles be saved as sphere geometry or will they stay as particles, as there are millions of particles in the cache.
Graham
Have you tried to turn “Recompute bounding box” on? If the stored bounding box in the file does not include the velocities it might happens such a thing.
Yes, we have tried that, with no luck. We are playing around with some different alembic export options to see if this helps. We seem to get the errors on different frames each time we generate the alembic file.
Is it consistent though? (i.e. if you re-render the same frame, you get the same wrong result)? What happens if you try to import the Alembic directly in Maya (f.e. with Exocortex)?
Hi, I have managed to create a cache with just two frames that causes the issue. The error is consistent but it changes depending what other geometry is in the scene, so in this sample scene if you hide a couple of the proxy objects then the chunk missing from the alembic file changes, it does look like some sort of bounding box error. Here is link to our file :- https://dl.dropboxusercontent.com/u/73974952/allembic\_debug.zip
Its 100meg.
If you have any problems downloading then let me know. Thanks
This will be fixed for the next nightly/stable builds tomorrow - if you don’t have access to the stable builds, please email us to support@chaosgroup.com and ask for them.
OK, I have downloaded nightly/stable builds and its now working with my test thanks
We will update a few farm machines and do some more complex tests next. I will let you know how we get on.
Graham
