I am experiencing a small issue with V-Ray proxies.
Basically, when I create a proxy out of an object and then import that proxy into a new scene, said proxy appears completely grey, with a default Lambert applied to it in the render window.
The issue is that V-Ray proxies, at least in Maya, do not automatically link the materials to the object. I have to do it manually in the Attribute Editor every time, which is kind of annoying to be honest.
Works fine on a simple scene when “Automatically create proxies” is active. Does it render correctly? Check the proxy’s Shader rollout - are there any shaders there? Maybe you’re getting confused by the grey viewport color of proxies.
It renders all grey, because the proxy shader rollout is empty.
That means I have to import my shaders, preventively exported from the hypershade (because of this problem), and reconnect them to the proxy, by populating the proxy shader slot.
What you need to do is once you have created your proxy and has been created in your scene you need to save the scene.
if you render at your pic2 you will see everthing is as it should be.
This scene now holds the proxy along with the applied materials, remember the materials only exist in the Maya scene and not with the proxy.
So once you have created your proxy save that maya scene and import the scene which will bring in the linked proxy and connected materials.
No dont think that would be saved, you’s need to apply it to the object after the proxy has been created.
if you only want it to go on a section of the model I think you’s need to “export each object as separate file” then apply it to that part.
