Hello, I have a scene of internal organs and most have a little movement on them; I also have blood flowing around inside with a Phoenix FD mesh. I don’t want to go the brute force method because of rendering time, so I’ve rendered an irradiance map cache separately (pre-anim). Now I’m rendering a light cache pass, set to single frame, but it’s currently rendering the full frame range. I also set to use camera path, even though camera doesn’t move, just the objects move. Even after rendering the IRMAP and VRLMAP, I’m not sure it will render good. More on that later though.
So does each light cache rendered (if setting is “single frame”) just overwrite the previous one, and I’m wasting time rendering all of them? Thanks for any help on this.
